[SOLD] Small Block Lunati VooDoo Hyd Cam 704
1969GTS340
Akron, NY
Brand new in the box, cam and lifters. Lifters are Elgin and Cam is Lunati 513/533. The Information below is from the Lunati page.
Hydraulic Flat Tappet. Hot street cam, likes 2800 converter, hi- rise type dual plane intake with 750 CFM carb, headers, 10:1 compression and 3.73 gears. Likes up to 200 HP nitrous.; Advertised Duration (Int/Exh): 276/284; Duration @ .050 (Int/Exh): 234/242; Gross Valve Lift (Int/Exh): .513/.533; LSA/ICL: 110/106; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 2200-6400.
$125. Plus the ride in USA.
