[SOLD] Small block manual steering no a/c pulleys and alt bracket
Moparbrad
You don’t know me
Phoenix,AZ
Rating - 97%
32   1   0
This is a set of matched, hard to find pulleys and alt brackets from a 71 small block. These are correct for 70 and newer but will work on earlier engines as well. In closed is all that's pictured: single groove crank pulley, water pump pulley, alternator brackets, 71 date code fan spacer, hard ware and correct alternator spacers.
In Phoenix AZ
$120 shipped in the U.S.
I am interested in the pulley's can I get the measurements straight across the pulleys?
These are sold but I have a power steering set available. Double groove crank pulley. Everything else is the same.
