earthmover
in the tire smoke
2 sets of j heads
1. set has milodon valves and all comp stuff locks,springs and all 2.02/1.60 if i remember right.heads took my 70 duster 7.40 in the 1/8 mile with a bad 60' of 1.67 $500.00
2. set has stock tulip valves in them with comp stuff lock,springs and all 1.88 valves i think ..had this heads on my motor when it was build the first time went 7.70 in the 1/8 mile with the cam in the wrong place and timing chain had a lot of slope init...(redid the motor and put a timing chain tens. in it ) and never put the heads back on went with the new valves in the other heads..$450.00
both sets has been ported and polished had the set with the milodon valves flowed ..went 240 or 250 and 140/150 will see if i can find the papers on them ...
3. torker 340 intake gasket matched no bad holes $125.00
stock 318 mounts from my 70 duster in good shape .bolt to motor and k all you need is the bolts 20.00
4. stock mp dizzy that been welded (locked out) worked great in my 340 $25.00 cap and rotor inc. also have a set of taylor wire about 5 pass. on them that will sell with the dizzy for 50.00 for all dizzy,cap,rotor,and wires may have some moroso wire clamps not sure if i still have them or not but will send if i do..got them new with the wire.. (sold pending payment )
5.big block fab valve cover new never been installed $100.00
indy 440-2 intake powder coated gray great shape only a few pass...and valley pan with the center that can be removed also poweder coated gray with vac. gauge hook up $350.00
also have mp blue valve cover for small block 45.00
all price are with buyer paying shipping..parts are in north caroilina 27816 zip
also will like to add i will make a package deal on both sets of heads and the torker intake for 900.00 for all ...........i have about 2600.00 in it all or a little more..
selling cause i no longer have small block stugg went 451 stroker big block thanks mike
will add pics of other stuff tomm..
6. small bolt patt. axles for abody housing 75.00
pics of heads at the bottom are not the heads sorry they are stock heads i have sold already..trying to del. the pic.mike
