[SOLD] Small Block QuickTime Bellhousing - New
Rocket
CT
For sale is a new QuickTime SFI approved bellhousing to mate small blocks to the new process 3 speed or 4 speed (A833) transmissions. Part number is RM-6072. The bellhousing includes the block plate, hardware and adapter ring to allow use of the 4.35” bearing retainer to the 4.81” hole in the bellhousing.
Some information for the Summitracing site
SFI-Approved: Yes
Safety Rating: SFI 6.1
Bellhousing Depth (in): 7.400 in.
Bellhousing Material: Steel
Bellhousing Finish: Black
Notes: Uses 130-tooth flywheel and no larger than 10.5 in.clutch. Transmission bore is universal 4.807”
QuickTime bellhousings are designed for Circle Track, strip, and street applications. Built from high-grade steel, the cone is spun, not rolled or stamped, allowing these bellhousings to be the most dimensionally stable and accurate for today's high performance vehicles. They offer proven performance and are built right here in the USA. Choose the size and specs needed for fitment on your particular vehicle, then bridge your transmission and engine with a QuickTime bellhousing.
Summits price is $692. I am selling this new bellhousing for $580 shipped in the lower 48 states.
