[WANTED] Small Block Timing Cover Hardware
What style water pump? Iron or aluminum? As far ras hardware do you need brackets for Alternator, power steering ,and pulleys?
Here one, for 69 and earlier water pump, thanks @TrailBeast
Someone here posted a pic with proper bolt length and orientation. I'm thinking it was Greg, @TrailBeast
But no idea where that is now.
I went from using a computer to using my phone and have tons of stuff I don’t have easy access to any more without connecting the phone to the computer with Itunes.
Ah ha, you found it.
Just as a supplement to this diagram....the stock bolts that went into the water jackets had built-in seals for the threads. When reusing them, yes, add some sealant. Also, those two lower 1" bolts should have sealer added too. they go into the timing chain area and can leak oil.
