small block water pump length?
rustytoolss
Clinton, Ohio
Cast iron pumps are shorter than Aluminum pumps...so what is the length of each ? this is for mock up (I know the lower hose is in different spot.
So , nobody has an aluminum water pump that they can measure the distance from the mounting surface to the pulley mounting surface ? I could use this information, to see if I have pulleys that may work.
Hopefully this will work for you if I understand your question.
There is about an inch difference as I recall. I have it all written down somewhere. I will look tomorrow.
