[FOR SALE] Small Bolt Pattern Slotted Mags
skidshoe93
Active Member
beaverton,ore
Rating - 0%
0   0   0
I have 4 American slotted mags 14x7 (see pics) small bolt pattern, $50.00 each + s&h Also have used small block crane cam 2-78-2nc, lift 467 & 494 with new lifters $100.00 + s & h To see more info go to crane sight & check out sm blk cam specs. I am open to offers
I hate to sound like a azzhole but I will not be able to use the wheels... I installed my rearend in my Barracuda today and I do not think that I will be able to find a backspacing in a slot wheel to work on the rear of it now so I'm guess I'll be going with a rally wheel. I put the cart before the horse on this and I apologize.
not quite as much room in the tail end of a barracuda as on a duster
but if your running an A body rear you should have no problem fitting a 7 inch wheel?
ok gentleman,I have a set of (4) American 14 x 7 mags wth center caps and lug nuts.(see pics) I don't want to break up set so I will only sell all 4,(if 2 people want 2 each at same time kool) UPS ground to 49424 aprox $35.00 x 4
