Does anyone have a recommendation for a small E clip removal and install tool for the SMALL e clips on some carburetors? I'm bout tired of using needle nosed pliers.
One of those handy little tools I didn't keep off the tool truck when I sold out.
Yep, those are great e clip tools. The Lisle tool I posted above is for hair pin clips. Like these little devils.in the lab we used a tool like this
https://www.amazon.com/Clip-Clips-Removal-Installation-Assortment/dp/B0D263899B?tag=fabo03-20
c-clip snaps in the end
the one we used had a screwdriver handle, and was longer than these
My auto shop teacher called the clips on drum brake parking brake levers Jesus clips, didn't take me long to understand why.Did anyone else ever refer to those clips as “Jesus clips”, or is that just a local thing from my past?
I have a set of picks and they work, but I want something to GRAB them so they don't slip off, fall off or go shooting off into the stratosphere. lolHow about these?
I don't see how in the world that works, but I bookmarked the one that's available.
I saw those but I don't know a size 3 from a size foe hunnit.in the lab we used a tool like this
There's a hook that comes out of the end. The spring is stout enough to hold the clip.I don't see how in the world that works, but I bookmarked the one that's available.
ok I think I unnerstand. Thanks Mike! That just might be what I need.There's a hook that comes out of the end. The spring is stout enough to hold the clip.
Jesus clip tool.ok I think I unnerstand. Thanks Mike! That just might be what I need.
Yeah. If it holds them good enough to install too that's the ticket.Jesus clip tool.
Was just going to reply that a friend of mine (who has since passed away) was an old time Mopar guy. He used to call them Jesus clips.Did anyone else ever refer to those clips as “Jesus clips”, or is that just a local thing from my past?
Wonder how those clips got that name?Jesus clip tool.
My friend told me it’s because when they fly off the carb and sail across the garage, you say “Jesus!”Wonder how those clips got that name?
Or when you drop it down the carb throat into the engine.My friend told me it’s because when they fly off the carb and sail across the garage, you say “Jesus!”
Puzackly.Or when you drop it down the carb throat into the engine.
