diymirage
HP@idle > hondaHP@redline
Just thinking here, some wire feeds have the ability to reverse the polarity. Puts more heat on the work instead of wire.
If I'm not mistaken, that's how you run fluxcore wire
It could be a 220 volt 120 Amp welder.No ****... I think most here know the difference between a 110v and a 220v plug.....
Transformer is too small![]()
I've said right from the original post it's a 120v machine.Back to square one. Is the welder 120 volt wall outlet welder, or 220 volt 3 prong electrical plug?
120 amp welder?
There is a huge difference between a 120 volt and a 220 volt machine.
I've said it was MIG with gas clearly before.It could be a 220 volt 120 Amp welder.
Needs to identify what it is. Gas Bottle welding or flux core wire?
Reversing polarity is for flux welding.Just thinking here, some wire feeds have the ability to reverse the polarity. Puts more heat on the work instead of wire.
Do you want me to remove it from the machine and get a picture of that end?Rusty if you can post a picture of the welding gun that is on it. Many of the smaller Tweeco Lincoln or Miller guns will have the copper break where it is connected to the brass block that goes into the machine. That will cause poor welding as it cannot carry the current. I always tell customers don’t use the gun as a pull toy
The only thing rubber there, you cannot see and that's an o-ring around the bulb end of the liner, right where the wire enters it. Other than that, no rubber. There's a copper "strap" that the gun sheath slides into that's one side (positive right now) of the electrical. Come to think of it, is that strap supposed to be "tight" around the copper part of the sheath? It just slides in and out. Seems that would be a poor connection, no? I do know that Kirk was pretty frustrated when he tried to last fix it. Maybe he forgot to tighten it up? I haven't checked it, because I'm unfamiliar with that part of this welder. I've used it a good bit, but never done maintenance on it. I'll check it tomorrow and see if it needs to be tightened there. That might be just how it's designed. I don't know.On that end of the gun is most likely a rubber boot that goes over the brass a bit. On the Lincoln guns there is a spring clamp that holds it in place. I don’t remember about the Tweeco. If you are able to slide that back and verify that the copper wire isn’t broken where it connects to the brass we can rule that out as a cause.
He actually put a new trigger on it chasing the problem.Contact tips on the gun trigger ?
Dirty contacts won’t pick the relay.
No. I fixed the binding. Now all it's doing is sticking and melting the wire to the work, rather than making an arc. I got it feeding real good, though.So, the wire binds AND the current isn't flowing correctly? Maybe the connection from the gun to the machine? I'm assuming it disconnects?
I know you tried reversing the polarity earlier, but is the polarity correct for gas shielded solid wire? Do you have .023 or .030 wire in it? The others are correct that an 80 amp machine won’t run .035 wire.No. I fixed the binding. Now all it's doing is sticking and melting the wire to the work, rather than making an arc. I got it feeding real good, though.
I'm not sure what amperage it is. I haven't been able to find that information. ....and please understand here, I'm not arguing the point, I'm merely point out what this machine has done in the past. It has .035 wire in it now and it has produced some good welds with that in the past. But yes, I've checked and double checked the polarity and it is right for the wire that's in it.I know you tried reversing the polarity earlier, but is the polarity correct for gas shielded solid wire? Do you have .023 or .030 wire in it? The others are correct that an 80 amp machine won’t run .035 wire.
