SleeperScamp
Any of you body guys have much experience using solder ?? What kind do you prefer silver , lead , lead free ????? Thanks...
I think SleeperScamp is asking about solder as used in "leading" or "metaling". The lead was used as a filler for seams, joints, holes, low spots, or patch panels. The stuff was toxic, though, and required a respirator. The "lead" solder they have nowadays is no longer toxic and can be heated and applied without the use of a respirator. The process is still the same, clean the area, flux the area, apply the solder with "cool" heat, and then file, grind, and/or finish the area. Although the new stuff is safe it still takes that old school experience to do it right. By the way, I don't have that old school experience. A good internet search should get you some information the leading.
