Just came across this tonight. Thought it was worth sharing for the oddity of seeing how things were produced back when our cars were built.
If only it was that easyAnd now all you'd do is hit that with a laser scanner and send the file to a 3D printer and viola, brand new grille bezels, tail lights etc
I used to scan and produce reproducible CAD, it's not that easy.
Scans are only so good, you have to go in and fill holes and repair scan defects. if the object being scanned is reflective you have to spray it with a coating which adds thickness albeit small. Small features can be obscured. Features that end up being shadowed by other features are not in the scan. Flat surfaces are far from flat.
Sorry bro, but patterns and models were made of soft wood, either sugar pine or Philippine mahogany. Almost all models for duplicating dies and plastic injection molds were made in mahogany.You’re just arguing semantics. You think it was easier to carve a precise model out of hardwood than correcting some defects on a scanned rendering? Talk about flat surfaces not being flat, heck of a lot easier to make it flat in CAD then in a piece of hickory. And nowadays I’m sure you’d find a lot more people that could fix it in CAD than carve it out of a block of wood!
There are classic car enthusiasts out there scanning parts and printing replicas. It’s not the best way to make reproduction parts, much better to have a mold if you’re making significant numbers. But for a tail light lense or interior emblem that no one reproduces? Yeah I’ve seen it done.
And 3D scanning and printing technology is improving all the time.
Scanning has come along way in such a short time.I used to scan and produce reproducible CAD, it's not that easy.
First, mahogany is a hardwood.
“Mahogany is a straight-grained, reddish-brown timber of three tropical hardwood species”
Mahogany - Wikipedia
And if you don’t like Wikipedia, well, you can check your local furniture store.
Second, I was just going off what the gentleman in the video said, those models aren’t something I’d seen before.
No, you suggested that 3D scanning and 3000 bucks you can produce all kinds of productsYou’re just arguing semantics
You have to admit that as time goes on the tech improves.No, you suggested that 3D scanning and 3000 bucks you can produce all kinds of products
I reverse engineer parts for our cars, some are printed in metal, some in plastic.
I don't 3D scan because I have done it where I last worked and all it was, was a basic frame work for CAD to be drawn around.
I can 3D print in many plastics and turn out a finished product in a day, depending on complexity on my resin printer here at home.
All of my CAD can be customized or modified as needed, a scan is like a photo and you are limited what you can do to it with any accuracy.
I have had some of my designs printed in metal (aluminum and stainless steel) by a 3rd party and their $100,000 machines produce some amazing results.
All I'm getting at is 3D scanning looks like amazing tech but in my experience it is not all its cracked up to be
Nice! Thanks for the great information!. A few years ago, I looked into 3D printing and found 3 problems: 1) Cost of adequate precision scanning devices 2) insufficient resolution (surface smoothness) of the plastic printers, and 3) cost and surface smoothness of metal printers. Which machines are acceptable for printing lenses? Which shops can print metal with sufficient surface smoothness?No, you suggested that 3D scanning and 3000 bucks you can produce all kinds of products
All I'm getting at is 3D scanning looks like amazing tech but in my experience it is not all its cracked up to be:
There are 3D prints services online that can print in metal st a sort of reasonable price.
Craftcloud is who was used. (IIRC)
As for surface smoothness of plastic printers, I suspect you were looking at FDM printers better material choices but crappy external surfaces.
UV cured resin printers can produce solid, smooth parts.
The one I have does 0.05mm ( 0.0019") layers.
Newer can do 0.025mm (0.0008") layers
The bottom housing was printed in stainless steel.
It polished up like a mirror.
I had one printed in Aluminum even smother right off the printer. I have not had that one polished yet.
The 318 badge was printed and finished by another member but is also stainless steel. From the same company.
This one has a sand cast finish between the letters
They are 3D printing houses!3d print anything
How did you digitize these parts?There are 3D prints services online that can print in metal st a sort of reasonable price.
Unreal!!They are 3D printing houses!
