Source wanted for the 2 pin connector harness on the dist or turn signals
Hyper_pak
Old School Chrysler Fan
Desoto Texas
I need a few of the polarized molded connectors used on the electronic dist. or turn signal indicators?
Anyone have a source?
I get them from the parts store,bwd electrical.
Pigtail with two connectors.
In a pinch you can cut up a 4 wire trailer plug.
Google 2 pin SAE connectors.
Also as stated above trailer hitch wiring
Look for 18 awg wire
Just avoid the similar "double bullet" connectors found on appliances as the male pins don't protrude enough to make assured contact (I know, wags will joke). I bought two e-distributor pickups the same time and found one didn't make a reliable connection. Apparently the factory had used an appliance connector. The other one had the proper SAE connector. Wonder if they bought a large lot of the wrong ones, which made a confusing problem for those who installed them.
I am going to use these on my front headlights with the 4 pin type to disconnect when the front end comes off my race car.
