Spare Tire Picture 68 Cuda
rsaun191
ct
Can some please post a picture of how the spare tire on 68 Barracuda Fastback is supposed to look when it is secured the way factory did it.Does the jack base lay on top of tire and get screwed down to hold in place.Or is there a little cup piece that is needed to use with stud.
spare center through bolt, jack base, pressboard cover, cup piece then the small wing nut.
http://dalescudashop.com/zjjain10.html
Yep, the jack base goes up-side-down with the round face down through the center hole of the rim with the flat face up, then the large wing nut, then the press board cover, then the cup, then a small wing nut like you can get in a hardware or parts store...
The large wing nut holds the spare tire and jack base from bouncing.
I forgot to add the large wingnut!
Hi, I'm trying to put the same setup together. Spare and jack and all associated hold in and trim parts. The link you shared just goes to the front page. I tried searching but no luck. Any suggestions? Thanks. 67 Barracuda
ps, found many of the parts on Classic. Not the bolt or hold down plate yet. I see I need a couple springs they offer to hold down jack but not sure where they att yet. Also there is a part they call an upper jack bracket? https://www.classicindustries.com/product/1968/plymouth/barracuda/parts/mm3080.html
I believe OP was interested in what components are involved, not where to obtain them. Evidently Dale's does not by a search I tried.
From the '69 OM..........
