Spark Plug Metal Washers
1970Dart198
Greenwich
Hi, I'd like to replace the spark plugs on my 198 slant six. I can get ACDelco spark plugs no problem at my local parts store. I've read on a few posts that the metal washer at the end of the spark plug's threads should be taken off.
Three questions:
How do I remove the metal washer from the plug without harming the threads?
What difference is there when the washer is out v.s. in?
Finally, If I replace the plugs, should I also change the spark plug wires as well?
Thank you in advance!
You learn something every day. I never knew about removing the washers. I've had my car since 1974. Thank you.
drool tube heads only :thumblef: later peanut head require the washer to stay on :coffee2:
