600 miles on the MRL engine. Normal to burn a little oil on a newly rebuilt engine? I thought timing was a little advanced. I will back it off some.looks like it's burning some oil and to much timing . from a quick glance
Ground strap color, how far down it changes color, the further...the more timing it has.Please educate me ... how can you tell the timing is too advanced by looking at this plug? The white tip? I would not have even considered timing.
Not currently using vacuum advance. Initial is 17 with 35* total at 3000 rpm. Edelbrock 600 running step #23
Initial is fine, bring the total down to 32 degrees. Most small blocks I build don't need more than that. Soot on the base ring would mean rich idle. Cut the plugs thread ring off to see wot color down near metal she'll. Remember... the base ring , for the most part, reflects what the chamber looks like.Not currently using vacuum advance. Initial is 17 with 35* total at 3000 rpm. Edelbrock 600 running step #23
