speedo cable
dodgenut7
Member
hey its me again i had to replace my speedo cable. my last one hit my header and i dont have to tell you what happened to it. i ran the other one alittle different but now my speedometer does not work. i did not kink it in any way but there is one kinda tight arc in it could this be my problem? i am not sure what is the smallest arc you can have in it so it will work any suggestions?
Maybe you sheared the gear? Disconnect the cable from the speedo and drive the car. Does the cable spin as you are driving? Yes=bad speedo, No=gear or cable. Try to get the cable as straight as you can. The tighter the bends, the shorter the cable life.
