my chart only goes up to 235-60-15, which shows 32 teeth or black. As the tire size increases the teeth decrease, so it may even be a 31 or green. Please note the colors are used with more than 1 tooth amount, so you should still count or look, most of the time the tooth count is cast into the plastic.
Rich
