red cuda Well-Known Member Joined Sep 8, 2013 Messages 228 Reaction score 5 Location water valley,mississippi Jul 15, 2014 #1 I measured my rear wheel from center to the edge. 11 1/2 inches. what size speedo gear do I need. thanks
pishta I know I'm right.... Joined Oct 13, 2004 Messages 23,824 Reaction score 13,683 Location Tustin, CA Jul 15, 2014 #2 Uh, what rear you got?> Generally, a stock sized tire uses the rear gear ratio X 10 for tooth count ie, 2.76 rear would use a 27 tooth gear, 3.9x would use a 39 tooth, etc. Itll get you close.
red cuda Well-Known Member Joined Sep 8, 2013 Messages 228 Reaction score 5 Location water valley,mississippi Jul 15, 2014 #3 uh.....geez.....uh......its a 2.76 gear. 15x7 wheels with 205/60-15 tire.
J jerry6 Banned Joined Aug 29, 2010 Messages 2,439 Reaction score 78 Location Mon Jul 16, 2014 #4 this might help http://www.mymopar.com/speedometer.htm
fishy68 Tyr Fryr's Inc. Joined Jan 11, 2005 Messages 16,584 Reaction score 1,264 Location Central, IL (Hooterville) Jul 16, 2014 #5 a 30 tooth should be real close as long as your speedometer itself is accurate
