Dcudaboy
Active Member
I've changed my speedo gear down to a 16 tooth and am still off about 10-12 mph @ 65. Does anybody know of a way to calibrate the actual speedometer? There is a brass nut, behind it a small lever that holds the gage needle spring, I'm thinking there is to much tension on the spring and should loosen the nut and relax the lever a small amount. Any ideas?
