I'm looking to lube the speedo cable and advice on removal from behind speedo. I'm assuming that is the best place to shoot the lube .
how does this come off? two screws? upper and lower? Or am i looking for a clip? im a little large and getting under the dash can be a bit challenging (with a warm-up though i can still do it). i saw in another thread that dry graphite is NOT the stuff to use. what is the recommended lube?
symptoms are....above 60 mph if i hit a bump the needle waves back n forth about a 10 mph swing with an intolerable noise.
Thanks FABO!
Thanks FABO!
