Speedometer Cables
Tims 66 Cuda
Mopar mid life crisis
Poquoson, Va
Hi all, I need a speedo cable for my 66 Barracuda. The correct length is 59" i believe. I can find a 61" will this work. I can also find a 59" but its for a Camero / Firebird. I wonder if this will cross over. Any help appreciated.
Tim
My 67 dart is 61" (physically measured)
It has a small screw on end for the speedo and a large screw on end for the trans.
Don't know if it is comparable.
You could check the 66 parts book and the 67 parts book and see if the numbers are the same
61inches with big end at the speedometer adapter and small en at the speedometer is what you need
