speedometer connection to bezel
Lowfat37
Prosser, WA
Hi. I am trying to remove my dash bezel in a 73 Duster with a standard bezel. Does anyone know if the speedo cable has a clip or button or if it screws in the back of the bezel? I don't want to break anything trying to remove it and I read in prior posts that removing the speedo cable shoud give me enough slack to remove the bezel and be able to disconnect the other wiring.
Thanks, I look forward to hearing from you all.
On my '71 Demon w/standard bezel, I disconnect the speedo cable by leveraging with a flat screwdriver = the cable is simply clipsed into the bezel.
Reinstalling it can be painful as there's no room for the fingers and it's a little bit tricky to reach the connector.
The speedo cable is held in place by a metal tab you have to press toward the cluster.
If you don’t have huge fat hands it can be released by reaching straight up through the column mounts.
Thanks for all the helpful replies! I got it and the entire cluster removed. Now working on identifying all the wiring.
