LivewireBlanco
Ok, so the two common guides I have found have conflicting speedometer gear teeth. I'm running 235/60R14 tires which should measure 25.1 inches tall and I'm going to be switching to 3.23 rear gears. I'm seeing 33 and 34 teeth being the correct size but I don't know which one is right. I can tell you right now that I have 2.76 gears and 28 tooth speedometer gear and it's dead on. Help!
