roadblock69
Member
I just swapped out my 7 1/4 rear for a 8 3/4. The gearing is 323 suregrip. I'm running 205/70/14 tires with the stock 904 transmission. My speedo is way off showing much faster than my actual speed. Can anyone tell me which speedo gear I should use to get the correct speed and where I can get one? Thanks in advance. The car had 13 inch wheels and 276 gears prior to the swap
