Swinging 69
Removed spider gears from my 489. They came out with shim's just fine. Can't get the replacement spiders with the shim's on back in , It's to tight of a fit. Why?
No idea, but if I ever have a tough time getting parts to fit together, I put that's too big in the freezer to shrink it down a little bit.
It's quite possible the replacement gears are made a few thousandths thicker, thus eliminating the need for the shims
They came out of another one, that's why I'm confused about it.where did you find replacement spider gears for the open carrier --- as far as i know there are NO replacement spider gears or side gears available for the 8-3/4 open carrier or 69 and up sure grip units --- were the spiders out of another 8-3/4 open carrier,,, if so they should fit with no issues .just install the thrust washer on the gears and rotate them into the case .
