Spring Locator Mount
Bad Sport
HALF A BUBBLE OFF
Staff member
Legendary Member
The Wolverine State
Does anyone have a front mount that's not installed for the inboard spring relocation?
If so, could you give me the dimensions?
Length, width (outside dimension and inside dimension from side to side), height toward the front and the location of the stock mounting hole?
Can anyone get me the measurement of the hole for the front spring eye (on center from front edge and on center from top edge). I would greatly appreciate it.
it goes straight through from the original mount
Pretty hard to determine where it would fall on the spring pocket without actually welding it in.
I'd like to drill before install.
