jrlegacy23
68 Barracuda
Yeah scott.. I have mine cut out. I have my location for my front holes. I am dropping them off tomorrow to get drilled and have the washers welded to the holes. Im having both correct location and 1" back drilled
What size tube did you end up using through the frame for the rear spring mount? I read on RMS that he has tubing in his kit for the 7/8" bushing, so is it 7/8" ID or did you use something like an 1" ID tube?
