springs
efriedrich
69 383S
Indiana
How do you no if you should change your springs. What I mean to ask is I will be putting the rearend back under my car shortly and I was wondering if I should put new springs in. It sat fine when I took it out, I dont think I had other any problems. I'm guess im just not sure if its needed.
If your happy with the way it sits leave them alone but while rear is out check all your bushings in your springs. Mine were shot.
If they were fine before they should be fine now. Springs will sag, ride height will change. If you were happy with the ride height I say run them.
