SRT8 Jeep manifolds and a 904 trans?
gregsdart
mn
After having done a ton of work to get those manifolds to work in a 65 Dart body, (coilovers, rack) I see it looks like there is no way the drivers side will clear a stock starter. Anybody solve this problem? If not, looks like I might have to build some headers#-o
Look into the 05 ram hemi with manual trans. It rotates the solenoid up to the top
Out of the way. There is a casting bump on the block that will have to be shaved
Thanks, I had a momentary panic attack, and forgot to look at available starters!
