SSBC Conversions
Jim Kueneman
Sonoita, Az
Who has done a SSBC conversion? The (crappy) instructions say reuse the lower bolts. It also says to drill out the one threaded hole in the spindle. The diagram shows putting the original bolts from the plate, through the spindle, through the lower ball joint then a nut.
Well the plate has threaded holes and the bolts do not go through those either.... did you drill out those holes or did you thread the bolt in from the lower ball joint side and thread into the SSBC plate with no nut?
Also where the hell do the 4 flat washers go? They are in the parts list but they are not listed in the text nor in the diagram...
Thanks,
Jim
Probably shouldn't have answered, I have Wilwoods, it's been a year but it seems like the brackets were spaced at the spindle with washers.
