[FOR SALE] Stage 6 top end
Scamp9572
Active Member
Wallkill, NY
Rating - 0%
0   0   0
Stage 6 heads complete. 1.5 Mopar rocker arms. Shafts. M1 Intake to fit RB.
Heads appear untouched. Came off 505 crate motor. I got them just like you see them. Don’t know much else. Also have purple shaft cam that was in the engine that appears pretty clean I will throw in. Believe it’s the 509.
Asking $1200?
What’s up with the 1 chamber? Thanks. Kim
I’m not really sure. When I picked it up it had been sitting under the guys shelf for years with the heads still bolted on the block. That cylinder had some rust it in it also. I thought maybe the head gasket wasn’t sealing and water or coolant leaked in over time. ?
The seller assured me it was a running engine when he pulled it out for a customer for an Indy crate. Whether to believe that or not? I got a pretty good deal On the whole thing but that’s what I found after tearing it down. Two cylinders actually the same way.
Posting more pics. It was only one chamber that looked like that and I do believe it was a bad head gasket. There is marking/discoloration at that chamber and that one only. I sprayed it with Kroil and hit it with a shop rag and it pretty much wiped right off. Did a before and after.
