[Found!] Standard bore 340 piston ring set
gzig5
Mequon, WI
When I took my engine apart to find out what the previous owners had put it together with, one of the compression rings was cracked. Very little bore wear so I had the block honed and I'm going to throw a set of rings and bearings back in until I get to the stroker build. So, I need a set of cast iron rings for a standard bore, stock piston, 340. 4.040". Let me know what you have and need to get for it. Thought I'd give someone the opportunity to turn their excess parts into cash before I put an order in to the part house.
Get a set of Chevy 4.00" + .040 they are cheap and the same 5/64, 5/64, & 3/16" oil ring as stock mopar rings. If it was honed 320 or finer use moly rings, they break in fast and seal better IMO
Hastings 2M139 .040 for "Moly" offering , or Hastings 139 .040 for "Cast" offering.
