Stantion Post Set.
drhood
Active Member
Hi Guys, im from Sydney Australia and im looking for what i believe to be called Stantion Post Set, these are the Rods that stand between the bonnet and a Hemi Dart Scoop... im am in need of 2 sets, any ideas where i can purchase these.. or if anyone on here has spares would you be willing to ship overseas... many thanks in advance..
George.
I'd use a carrige bolt and some thinwall aluminum tubing purchased from a hardware store. While not exact, it's awful close and might cost you $10 bucks instead of what I see as lots of bucks for hemi anything. Best of luck in your search.
George.
AAR sells a stantion set for US$30
http://www.aarqualityfiberglass.com/cart2/popup_image.php?pID=449
Alternate idea is to get some 10mm-dia. aluminum rod, cut to length, drill and tap each end for either machine screws or button-head screws. Install with correct size washers for added support and you're done.
