clifftt
Looking for help before I pull the tranny pan off. I replaced the o-ring at the end of the shifter cable and also the transmission pan gasket on my 904 to cure leak issues. Filled it with fluid, found no leaks, then went to start it. Starter would not make a sound. I figure it had to do with the shifter cable not quite adjusted right with the neutral safety switch, since I neglected to check that when I inserted the shift cable back in.
Not wanting to pull the pan off again, I adjusted the cable, in half-turn increments from all the way in to all the way out, checking to see if it would start each time. Starter still wouldn't engage.
Nothing else done to the car, new battery and always have the Battery Tender running on it. This thing started beautifully a week ago.
I think I'll have to pull the pan off to make sure the neutral safety switch is inline when the cable is set to "N"eutral, but I'm open to other ideas or opinions before I pull the pan off again.
