RDJ
My TTI headers touch my mini starter. Do others have this problem? Will my starter fry? Obviously the rubber cover on the bolts will melt if I don't remove them. What have you done to fix this?
Yep mine was pretty damn close too. You have to reroute the lug on the stud so that it is facing down and you will have to do away with the rubber insulator and use insulating tape instead.
Is that a Mopar mini-starter??..they come with extensions on the studs to keep the cables away from the headers,mine come no where near the header tubes..
