[FOR SALE] Station wagon tailgate manual crank adaptor
cudamark
San Diego
If you own an early A-body (and even some B-bodies) station wagon with a manual tailgate, you will need this part sooner or later. Being some version of aluminum/pot metal, they can and do wear out. This is the part that goes between the crank handle for the window, and the actual window regulator. A common part to strip it's splines. It's part number is 2299746 and fit's '63-6 A-body wagons for sure, and some '63-4 B-body wagons. Maybe others as well, but, do your own research to verify it fits your application. The power tailgates don't use this part. Manual gates only. $45 delivered to a first 48 state U.S. address only. I take PayPal, so, add $4 unless you use friends and family. Thanks, Mark
