[SOLD] std bore 340 block and parts will seperate
moparraceman
mansfield ohio
1972 340 block standard bore ,steel crank std , block has been cleaned ,and freeze plugs and cam bearing removed.new cam bearings, and new freeze plugs are encluded.has stock 340 rods,oil pan ,windage tray,excellent timing cover and seal,steel crank damper,head gaskets,bronze bushing for distributor. hughes hyd cam ,no lifters NO PISTONS ARE ENCLUDED $1625 pick up ohio mansfield NO SHIPPING NOTE WILL SELL BLOCK AND CRANK FOR 1250 firm ohio
