mitch340Duster
I'm sure I'm not the first to do this but I thought it might be worth sharing. Some guys will disagree with this since I'm striving to keep everything on the car correct, but ya gotta have tunes, and the factory AM radio aint enough.
So, I ordered a repro shelf panel, but one for a car with rear speakers. Mounted the amp between back seat and trunk. With a smaller amp you might not even be able to see it from the trunk, but I had this amp "in-stock".
Installed a pair of Alpine SPR-69 speakers. They fit perfectly in the factory 6x9 cutouts.
Running the power, amp remote, and audio cables from amp to dash hidden along with the body wiring harness. AM radio stays in the dash, music is provided courtesy of an ipod in a location TBD after the interior is together.
Best of all...My buddies and I have been fiddling with car stereos since the 70's. I've had bi-amp, tri-amp, multiple speakers systems, SW's, etc but this setup is by-far the best I've ever had. Perfect example of KISS (Keep It Simple Stupid). Only mods were 2 small holes to mount the amp, along with double-sided tape, and I had to enlarge the screw holes only for the speakers to accept M6 screws.
