plugger340
Is there anyway to minimize the alloy wheel corrosion that occurs when the alloy rim seats against the steel rotor? There is always enough corrosion (from dissimiliar metals reacting - aluminum against steel) that I always have to kick on the tire's side to break the bond. Sometimes I have to rotate the tire a few times while I beat on it. Does anything work to minimize the corrosion ; like wax or oil?
