steering box removal
danthedewman1
Ava, Missouri
I have a 72 Dart and was thinking of pulling the steering column and the steering gear box out.The steering box looks pretty easy ,but getting the column out from there might be tricky.Any suggestions on how to do this.Thanks,DAN
steering column first,,,,remove column trim,four screws attaching it to dash,two bolts under column at dash support,and three bolts at firewall flange,,,,,,now move to the engine compartment and with a 1/4" drift pin, remove expansion pin at top of steering box where joint is,,,, oops back up and under dash unhook wiring harness. steering column should slide right out. the box is pretty much cut and dry, three bolts and the pitman arm
