70 Dart Swinger with auto trans.
I needed to change a turn signal switch inside the steering wheel column, so I took a bit apart.
Nothing was done to the trans. itself. Now, the car shifts weird, it is shifting from 1 to 2 very late, like at 25 (and harshly). And I put in two, and it moved by itself to one. What do you suppose I did wrong when I put it back? And if I moved the shifter from D to 2, and back to D, it drives normally (ie shifting from 1 to 2 around 15). But then it comes back again later same problem as before.
