steering column wiring
Patmo
Member
Mississippi
Hey guys, got a 74 scamp i pulled column out to put a universal joint on shaft , when i pulled it out some of the wires on the connectors came out (dont think i was first person in there) does anybody have any picks of connectors with the wires in them? Thanks in advanced!
Can't you match them up with the colors of the other plug?
Big red is power coming in. Be careful and disconnect battery NOT FUSED
Big black is "ACCessory" feed
Dark blue is ignition "run" IGN1
Brown is ballast bypass or IGN2
Yellow is start wire
