Steering Column
johnnycuda
JohnnyCuda's 68
68 Barracuda 340 auto formula "S"
I was wondering if sombody can tell me if there is a difference in Lenght
"Ha Ha" from a manual column to a power steering Column???
My car has a 3 inch adaptor because it has a manual box and a P/S column.
anybody wanna swap It's an auto with a floor shift.
Another issue is the steering wheel is crooked and i dont know where to adjust it?
Help:mumum:
The splines on a manual box are larger too so you will need a coupler with the longer column. I would disconnect your pitman arm from the center link and turn the steering wheel lock to lock to center it and then reset the toe.
