I just did this yesterday, the spring clip goes up against the cross shaft first, say the side facing towards you with the steering shaft vertical, there should be a cut out on the spring for orientation, then the shoes go on the cross shaft with the curved side out. The spring clip will go over the tops of the shoes. The clip will fit in the shoe tops. You will have to fill the coupler with grease about 1/2" from the top, then squeeze the shoes together and slide them in. Worked real slick. I got my rebuild kit from Moparts, good guys.
