Steering ujoint , aftermarket for 70 Dart ps
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
Put on Dougs D453 headers today 70 Dart, 360 magnum power steering. Very tight fit.
Ps box to tube clearance is not Good. I will have to washer the engine mounts up to gain more clearance to put a high heat insulating blanket on the box. The steering coupler also has minimal clearance. I am thinking that a flaming river u joint will work. Does. the joint have to be welded to the shaft ?. is the coupler to the box mopar specific splines?
Can you recommend a specific product ?
Any info will be helpful.
Borgeson has a selection of u joints with the Mopar spline (5/8-36 I believe), with differing opposite ends depending on your needs.
Make sure you get the one labeled for Chryslers, as the GM 5/8 36 is different and will not fit.
Borgeson is only showing a 3/4 DD-x5/8-36 GM spline, no Chrysler ones ?
