Steering wheel not right
Suspension, Steering and Chassis
  1. gtxdude
    gtxdude Well-Known Member
    426
    163
    Apr 30, 2011
    Bloomington, MN
    Local Time:
    11:59 AM
    Just put new pitman arm in Dart, went for spin and car steers much better. Old arm was pretty warn out and loose. Anyway I noticed my steering wheel isn't lined up correctly now when I'm going straight, it's off a quarter of a turn. Do I need to remove pitman arm and rotate over one click? There's four groove's that line up with steering gear, is it possible I'm one off? Or is this a alignment issue for the shop? 2nd picture is where it's at going down road. I'll check back later, thanks
  2. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,432
    1289
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:59 AM
    Did u put it back on in the same place as the old 1? Try counting how many turns left of center then how many to the right. Let us know the answers. Kim
  3. Kern Dog
    Kern Dog Well-Known Member
    2,671
    2233
    May 23, 2010
    Granite bay CA
    Local Time:
    9:59 AM
    The car may have been aligned to the sloppy condition of the old pitman arm.
    No, you could NOT be 90 degrees off on the pitman. To do that, your steering range would be seriously limited to one side while all the way past the stops to the other direction!
    • Thanks! Thanks! x 1
    • RustyRatRod
      RustyRatRod 30 Degrees Outta Whack FABO Gold Member
      49,131
      15310
      Jun 7, 2010
      Georgia
      Local Time:
      12:59 PM
      Actually, he can be off that much. SOME aftermarket pitman arms have FOUR different positions that they can be installed in, denoted by four master keyways across from one another. It would have no effect on the steering range, because all it would do is turn the wheel to a different position, like he is experiencing.
      • RustyRatRod
        49,131
        15310
        Jun 7, 2010
        Georgia
        Local Time:
        12:59 PM
        This is a typical aftermarket Mopar pitman arm. It has four distinct master keys that I have circled. It can be installed in four different positions, each will position the steering wheel correctly, 90* off either way, or 180* off and will retain the same steering range as if installed correctly.
        • gtxdude
          426
          163
          Apr 30, 2011
          Bloomington, MN
          Local Time:
          11:59 AM
          Took car to shop, and they adjusted toe in, out and what ever else was needed and straightened it right out. Will have to drive this weekend and see how much better steering is. thanks everyone
        • oldkimmer
          10,432
          1289
          Nov 11, 2006
          Local Time:
          11:59 AM
          Great, hopefully they checked the rest of the front end. Kim
          • Like Like x 1
