Steering Wheel Swap....any advice???
rod locker
Changing from stock wheel to a Grant Classic on a '74 Duster. My horn button is round compared to the horn button that is shown in the Haynes Manual.
1) How does the horn button come off?
2) Do you have to remove the turn signal cam to install the installation kit and new horn button?
3) Any other little hints I can get will be appreciated.
Thanks,,,,,,,,,,,,,,,,,
I'm guessing the horn button will twist off. You'll probably need a puller to get the wheel off. No, you don't need to mess with the turn signal switch . Make sure they gave you the correct adapter kit. When I did the wheel on "IT", the horn didn't work until I scraped some paint off the wheel so the button would make contact.
