Has anyone ever heard of this type of problem? At first start up my clutch pedal moves perfectly smoothly. Once everything warms up it sticks so badly that it the pedal releases in big steps. From a dead stop you have to guess where to stop letting the clutch out to for partial engagement. It makes it look like you don't know how to drive a stick.
It has a new throw out bearing that pushes on a Center Force Dual Friction clutch. I removed the big overspring when I upgraded to the Center Force. It worked fine since 2002, but last year it started hanging up. The TTI headers clear the Z bar and I have grease on the tube that the throw out bearing slides on. I can't believe that the pressure plate is hanging up. It is a little hard to get staged but I have made a bunch of passes with it like this.
