ice1 dart
Member
Got a 75 dart swinger with a big block 440 stroked out to a 500. i have a mild roller rocker comp cam with a 113 lsa split. the cam duration @ .050 is 230/236 and lobe lift is at .389/391. mechanical timing is set at 0" and the heads are edelbrock 84 cc rpm heads. The total compression is 10.7 :1 Block is freshly boiled and rebuilt with no scales nor cracks.
Fuel deliveriy is a first gen edelbock pro flow series multiport fuel injection w/42lb injectors. Per edelbrock base distributor timing is set at 10deg BTDC. This system will allow individual ajustement to timing and fuel electronically from hand held. Fuel is running a little on the fat side so lean problem here. (A/F range from 12.5-14)
Cooling system is being pushed with a high flow edelbrock w/p and it has high flow 180 deg tstat. The radiator is an alum Champion down flow radiator 26w X 22 h (total including tanks). I believe its a three core radiator. (not sure/ overall thickness is about 3") The fans are two electric pushers (16" (3630 CFM) and 12"(unknown) (no room for a shroud) Fans are set to come on approximately 180-185.
Problem: At idle and cruise the temp will slowly and progressively get hotter until I am forced to shut it off at around 211-213. During cruise the process is a little faster. While cruisng at 60mph (RPM is about 1300-1400) the temp will steady off but as the journey continues so does the temp. Fans will kick on but will not cycle off. Feels like engine is generating too much heat that the radiator cannot shed it off.
Spoke to a few people and they believe it was the electronic timing in either each individual cells or in the global (overall) timing. Played with the adjustment by retarding and advancing the timing and felt a little difference in proformance and very little change in condition. (so far no pinging that i can here or feel)
Others people believe it is a mechanical problem and is blaming the cooling system overall. I dont believe this is the problem because the radiator is rated for 750+ hp and the fans are moving a ton of air. (3630 CFM plus whatever the 12" is pushing).
I feel I need to dyno and tune the engine so i can eliminate one suspicion but speaking to a dyno guy in my area, he feels it will not solve the problem and believes its more mechanical.
Im stumped..... Need help....Dyno? or No Dyno? Cooling System Problem or timing problem ?
If anyone is running this system, your advice or at least a known good shop in the northern california bay area that can help is greatly appreciated. Hehehe. (Slowly giving up on figuring it out myself.) :banghead::banghead::banghead::banghead:
