OlDuster
I have been told my problem is probably in my turn signal switch. I pulled the wheel and checked out the circuits. I have power to the horn and power to the emergency flasher switch. NO POWER to the turn signals. Now, power at the horn and emergency switch removes the concern about the harness not being connected. My lights work fine when the emergency flashers are working so no bulb or ground concerns. Why no power to ANY wire on the turn signal switch? I know the brake light switch is working. When I touch the pedal, it lights up my 'light'. I understand the brakes lights go through the turn signal and then out to the correct bulbs. What is going on here? Any ideas from the NEW BOARD!
